請問一下,我的Intel(R) HD Graphics Control Panel顯示找不到GfxUIEx.exe,但我在資料夾搜尋後,發現有3個檔名一樣的東西,但日期卻不同,我應該設定哪一個來開啟?有3個檔這樣正常嗎?
Hello kuri,
After translating your message I understand your computer is missing the GfxUIEx.exe file.
Let me apologize for any inconvenience this issue may be causing to you.
In order to help you better I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .txt file the Intel® System Support Utility will generate https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Let me also know if there was or not any type of software or hardware change before the issue started happening.
To attach a file, you must click "Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
Fred D.
Hello kuri,
I was wondering if you still need assistance regarding the file your computer is missing. In case you still assistance just let me know.
Fred D.
現在我把在開啟路徑移到別處資料夾的最新版GfxUIEx.exe,就可以正常使用,我得詢問是想確認他是否正常,而不想在不清楚是何種檔的情況下去下再額外的東西,謝謝你的再次詢問,如再有同樣問題發生我會照著上面的方式處理,謝謝你,辛苦了!
Hello kuri,
Fred D.
Hello kuri,
Fred D.
![](/skins/images/C4F7392A5C68ACA60290C9576F107044/responsive_peak/images/icon_anonymous_message.png)
