Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4657 Discussions
Intel® Remote Management Module 4 hangs up web access
SPetr4
Hello, dear sirs.
I recently got a new Intel server
PROD.CODE: R1208GL4DS
SERIAL NO: FHBU228100Q
TA.NO: G52092-001
I continiously experiance problem with Intel RMM 4 preinstalled chip.
After power on this server RMM works normally for several hours. After that it suddenly stop responding via it's web interface.
Btw., ssh seems not to responding as well.
From BIOS I can read following virsions:
Board Part Number: G29051-352
Board Serial Number: QSGR22000785
BMC Frimware Revision: 1.00.2612
ME Frimware Revision: 02.01.05.091
SDR Revision: SDR Package D.08
UUID: 0E213A40A30811E1-B523001E67490CE4
Can you, please, provide me with instructions on how I can eliminate this problem?
I read on several fourums that may be frimware update can heal my system from hangs ups.
Thank you!
Sergey Petrunin
Update: upgrading frimwere to lastest version (from 09/18/13) do not help. Problem remains.
Edward_Z_Intel
Yes I would also recommend a firmware update first since you're running a quite old version. Here is the latest version: https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23196 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23196
