Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
5015 Discussions
Intel S5000PAL - IPMI/BMC LAN ACCESS
ANieś
in my environment i have server with two nic on board, where:
  • nic1 (first nic) i want use it for ipmi sol
  • nic2 (secon nic) i'm using it for server connection
I have configured ipmi lan like below:
ipmitool lan print
Set in Progress : Set Complete
Auth Type Support : NONE MD5 PASSWORD
Auth Type Enable : Callback :
: User :
: Operator :
: Admin :
: OEM :
IP Address Source : BIOS Assigned Address
IP Address : 169.254.202.35
Subnet Mask : 255.255.255.0
MAC Address : 00:15:17:a8:1e:d2
SNMP Community String :
IP Header : TTL=0x40 Flags=0x40 Precedence=0x00 TOS=0x10
BMC ARP Control : ARP Responses Disabled, Gratuitous ARP Disabled
Gratituous ARP Intrvl : 2.0 seconds
Default Gateway IP : 169.254.202.254
Default Gateway MAC : 00:00:00:00:00:00
Backup Gateway IP : 0.0.0.0
Backup Gateway MAC : 00:00:00:00:00:00
RMCP+ Cipher Suites : 0,1,2,3,4,5,6,7,8,9,10,11,12,13,14
Cipher Suite Priv Max : XXXXXXXXXXXXXXX
: X=Cipher Suite Unused
: c=CALLBACK
: u=USER
: o=OPERATOR
: a=ADMIN
: O=OEM
From what i read ipmi 1.5 isn't supporting vlan tagging. NIC is connected to switcha with configured access vlan(untagged traffic or port vlan)
Unfortunate ipmi lan doesn't respond to icmp traffic.
Attached configuration works properly on other servers, but this model does not want to cooperate. I checked the configurations on other identical server configurations and the behavior is the same everywhere.
My OS: Linux
Thanks in advance for any help
We would like to inform you that the board you are looking support is end of interactive support (EOIS) reason why we suggest visiting our website for further assistance:
http://www.intel.com/content/www/us/en/support/server-products/server-boards/legacy-server-and-workstation-boards/intel-server-board-s5000pal-family.html Intel® Server Board S5000PAL Family
ANieś
I was able to solve the problem. If someone had a similar situation the solution below.
ipmitool lan print 1 returns
"BMC ARP Control : ARP Responses Disabled, Gratuitous ARP Disabled"
important part ARP Responses Disabled, so ipmitool lan set 1 arp respond on change state to ARP Responses Enabled
That's all.
