Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4995 Discussions
IPMI vlan and host vlan on one nic
ANieś
can i have the same vlan on host nic1 and ipmi lan ?
The situation looks as follows:
1) server with two nic (NIC1 and NIC2, but we only use NIC1)
2) in linux on server NIC1 (name eth0) i create tagged vlan:
ip link add link eth0 name eth0.101 type vlan id 101
ip add add 169.254.203.254/24 dev eth0.101
3) configure ipmi
# ipmitool lan print
Set in Progress : Set Complete
Auth Type Support : NONE MD5 PASSWORD
Auth Type Enable : Callback : NONE MD5 PASSWORD
: User : NONE MD5 PASSWORD
: Operator : NONE MD5 PASSWORD
: Admin : NONE MD5 PASSWORD
: OEM :
IP Address Source : Static Address
IP Address : 169.254.203.1
Subnet Mask : 255.255.255.0
MAC Address : 00:1e:67:21:3d:be
SNMP Community String : INTEL
IP Header : TTL=0x00 Flags=0x00 Precedence=0x00 TOS=0x00
BMC ARP Control : ARP Responses Enabled, Gratuitous ARP Disabled
Gratituous ARP Intrvl : 0.0 seconds
Default Gateway IP : 169.254.203.254
Default Gateway MAC : 00:00:00:00:00:00
Backup Gateway IP : 0.0.0.0
Backup Gateway MAC : 00:00:00:00:00:00
802.1q VLAN ID : 101
802.1q VLAN Priority : 0
RMCP+ Cipher Suites : 1,2,3,6,7,8,11,12,0
Cipher Suite Priv Max : caaaXXaaaXXaaXX
: X=Cipher Suite Unused
: c=CALLBACK
: u=USER
: o=OPERATOR
: a=ADMIN
: O=OEM
4) connect NIC1 to switch with tagged vlan 101
With this configuration i can't connect to ipmi from Linux when i run ping 169.254.203.1 i don't receive response
ARP table on the switch show only mac od the NIC1 in linux host.
I am doing something wrong or such a solution does not work?
To answer your question, you cannot have the same vlan on host nic1 and ipmi lan. It is not supported.
ANieś
Thanks DAN,
another question.
If i create tagged vlan for ipmi and i want to be able to connect in. I need to have server with access to that vlan, if that server is intel brand i can't have ipmi on nic where i have access vlan to ipmi network.
How can i solve problem where i need to have tagged vlan on nic to access ipmi and tagged vlan on ipmi on the same NIC ?
