Server Products
4874 Discussions
Intel SASWT4I problem
I have a problem with Intel SASWT4I RAID controller. The controller is in the resyncing state and I'm unable to access RAID BIOS utility by pressing ctrl+c. The message says that the utility is being loaded but then it says "No Boot Device Found". If I don't attempt to get to the utility, it will boot to the windows.
I'm using MSI board and two Intel 320 series SSD drives.
Any ideas why I would not be able to access BIOS utility??
Thanks!
We did update firmware and still no go. We even wiped the SSD's and bypassed backplane and still can't get to RAID Utility by pressing CTRL+C. The next step is to try regular hard drives. Any ideas what went wrong? It worked fine for 2 weeks, and now it doesn't.
