Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4852 Discussions
Intel® Server System R1304GZ4GC and Intel Integrated RAID Module RMS25CB080
cdabb
hi there,
new user here
I have recently purchased a R1304GZ4GC 1u server with the integrated raid controller. Unfortunately im after something that can support JBOD disks so i can manage the disk with software. I know im loosing out on performance but im comfortable with software raid systems.
I updated all the Bios Firmware for the system with success when i first got it. Im going to use the onboard sas controllers
I would like to remove the module and battery backup unit but when i removed the module the system would ramp up the fans to 100% on the one side. The server BMC web health status shows a BMC error.
BMC FW HealthManagement Subsystem Health
'' sensor has failed and may not be providing a valid reading - Asserted
So its complaining about the temp sensor on the module missing as i have physically removed it. Should this actually throw a error in the first place? If so how do i get the server to not look for it, is there a BMC reset/refresh/rescan option im missing in the bios.
If someone could point me in the right direction to overcome this error i would be grateful, i have replaced the raid module and things are back to normal. But i would like it removed and sold on so its at least put to good use somewhere.
Craig
Hello Craig,
It should have not been an error in the first place, I would recommend clearing the logs in the BIOS and compare results from there.
If the issue continues, I would recommend running the firmware again without the RAID controller and compare results.
Dave A.
Were you able to run the firmware again and compare the results?
