I have a problem with teaming configurationn of Intel Pro/1000 PT QUad port LP server adapter.
I am able to create the teaming using the script under the C:\Program Files\Intel\NCS2\Scripts\
However,Each time After the system idle for about 10min,
The script no longer able to query the teaming information and i need to reboot the server to make it work again.
I am wondering it is the WMI provider problem
Is there any idea on how to resolve this problem?
I am using the installer PROEM64T.exe v 4.0.100.1124
Alan Jim
Once the team is created, the script shouldn't need to continually query. If you create the team through the OS, is it stable? Are you using XP or 2003?
