I created a node js project into my Intel XDK. I use an Intel Edison and I want to use it as a web server.
I want to create an index.html page where there is a button and when the button is pressed it is launched a python script. I'm new on Edison and I have no idea to start with python on Edison.
Any help is appreciated.
Best regards.
Giuseppe
- Tags:
- Intel® Makers
- Python
I will be moving this to the corresponding /community/tech/edison support group.
Hi Giuseppe,
Having your python code in your board, you can use a system call in order to start it.
For example if you have a code named blink.py in /home/root you can create a Javascript code to run it with:
var SC = require('child_process')
SC.exec("python /home/root/blink.py")
I hope this helps.
Charlie
Hi Charlie,
I tried with your suggestion but it doesn't work.
This is my mani.js:
//Required
var mraa = require('mraa'); //require mraa
var Cylon = require ('cylon');//require cylon
var querystring = require('querystring');
var express = require('express');
/////////////////////////////////////////////////START//
//Set Public folder
var app = express();
app.use(express.static(__dirname + '/public'));
app.get('/', function (req, res) {
res.sendFile(index.html);
//Start Listening
var server = app.listen(5555, function(){
var host = server.address().address;
var port = server.address().port;
console.log('Example app listening at http://%s:%s', '192.168.0.179', port);
//Start dialog with index.html page
var io = require('socket.io').listen(server); // to dialog with the webpage
io.sockets.on('connection', function(socket){
//recieve client data with CYLON
socket.on('client_data', function(data){
socket.on('launch_on', function(){
var PythonShell = require('python-shell');
SC.exec("python test.py")
console.log('script launched');
and this is my HTML page with the button (when it is pressed it is launched the python script):
<!DOCTYPE html>
Elaborazione dati ECG-GSR
https://cdn.socket.io/socket.io-1.3.5.js https://cdn.socket.io/socket.io-1.3.5.js">
https://ajax.googleapis.com/ajax/libs/jquery/1.7.2/jquery.js https://ajax.googleapis.com/ajax/libs/jquery/1.7.2/jquery.js">
//Connect with the server
var socket = io.connect();
//Send data to the server
$(document).ready(function(){
socket.emit('launch_on', {'message': 'launch_on'});
$('# launch_on').click(function(e){
socket.emit('launch_on');
<!---------------------------------- BODY ----------------------------------->
Launch python script
Lancia Script
Hoping this is helpful for a solution.
what does "does not work" mean? do you get an error message?
Maybe you need to put the full path "/usr/bin/python"?
"does not work" it means when I press the button on the HTML page the python script don't show any result.
My python script is a simple print.
This is my HTML page in the browser.
Hi Giussepe,
Do you have updates on this?
I saw on your code that you are not using Python-Shell, have you tried with something like:
PythonShell.run('test.py',function(err){
if (err) throw err;
console.log('finished');
Charlie
Hi Charlie,
I try with your suggestion:
PythonShell.run('public/test.py',function(err){
if (err) throw err;
but I receive the errors shown below. The file test.py is located in the public fold.
Some idea to resolve these errors?
giuseppe
The express app is running
Example app listening at http://192.168.0.231:5555 http://192.168.0.231:5555
ERROR: /home/root/.node_app_slot/main.js:36
ERROR: if (err) throw err;
ERROR: ^
ERROR: Error: python: can't open file 'public/test.py': [Errno 2] No such file or directory
at PythonShell.parseError (/home/root/node_modules/python-shell/index.js:173:17)
at ChildProcess. (/home/root/node_modules/python-shell/index.js:80:28)
at ChildProcess.emit (events.js:98:17)
at Process.ChildProcess._handle.onexit (child_process.js:820:12)
Hi Giuseppe,
Have you tried to put the entire location of the file instead of using public/test.py?
Also, is the same outcome when you put the test.py in the same folder of index.html and your main.js?
What is the output of running:
node --version
npm --version
configure_edison –version
Kind regards,
Charlie
Hi Charlie,
putting test.py in public or in the same directory of main.js don't changes anything. I have this error:
Example app listening at http://192.168.0.128:5555 http://192.168.0.128:5555
ERROR: /home/root/.node_app_slot/main.js:39
ERROR: ^
ERROR: Error: python: can't open file 'test.py': [Errno 2] No such file or directory
at PythonShell.parseError (/usr/lib/node_modules/python-shell/index.js:173:17)
at ChildProcess. (/usr/lib/node_modules/python-shell/index.js:80:28)
The results of the commands suggested:
root@edison:~# node --version
v0.10.38
root@edison:~# npm --version
3.3.10
root@edison:~# configure_edison --version
159
Thanks for your attention.
<p style="font-family: Menlo, 'DejaVu Sans Mono', Consolas, 'Liberation Mono', Courier, 'Ubuntu...- Mark as New
Hi giuseppe,
I would like to know if you are running the same code as the one is attached.
Also, could you post a screenshot of what you get when you type ls -la in the folder where you have the main.js, the index.html and test.py?
Charlie
Hi Charlie,
the code used is the same of my past post.
This is a screen shot of my Intel XDK IoT Edition when I give the ls -la command.
Giuseppe.
Thanks for your replies.
I put my test.py in the root directory and I tried with:
PythonShell.run('../../root/test.py', function(err){
if (err) throw err;
console.log(err);
as suggested but I have these errors:
Example app listening at http://192.168.0.154:5555 http://192.168.0.154:5555
ERROR: ^
ERROR: Error: python: can't open file '../../root/test.py': [Errno 2] No such file or directory
I have no idea...
giuseppe
try listing the files in '.' and '../../' from within your Javascript (e.g. http://stackoverflow.com/questions/2727167/getting-all-filenames-in-a-directory-with-node-js http://stackoverflow.com/questions/2727167/getting-all-filenames-in-a-directory-with-node-js) and check which files are visible
Hi Giuseppe,
If the error appears only when you press the button on the website. Try to use path, like:
var path = require('path');
app.get('/', function(req, res) {
res.sendFile(path.join(__dirname + '/index.html'));
Also try by setting test.py as an executable using the Terminal Console with chmod +x test.py
Without pressing the button, do you receive error messages? Does the website works fine until you press the button?
Charlie
Hi guys,
thanks for your replies.
With the suggested code in the posted question I am not able to have the files list, I have many errors.
The test.py in root directory I set the 777 permission but don't changes anything.
After run the script (without pressing the button in the index.htm page) I have the errors:
Upload Complete
App is already running
Example app listening at http://192.168.0.204:5555 http://192.168.0.204:5555
ERROR: /home/root/.node_app_slot/main.js:45
ERROR: ^
ERROR: Error: python: can't open file '../test.py': [Errno 2] No such file or directory
Pressing the button don't happen anything.
I have no idea how to resolve all these problems.
Hi Giuseppe,
I tried with this example: http://socket.io/get-started/chat/ Socket.IO — Chat Using the 159 version, I was able to run a similar code than the one you are using, but you will need to work on the reception routine to run the python script. Take a look at the following code.
var app = require('express')();
var http = require('http').Server(app);
var io = require('socket.io')(http);
- app.get('/', function(req, res){
res.sendFile(__dirname + '/index.html');
- io.on('connection', function(socket){
if (err) throw err;
- http.listen(3000, function(){
console.log('listening on *:3000');
If you have the main.js, index.html and test.py in the same folder you shouldn't have problems, you will just need to access to the IP address of your board on your web browser (like 192.168.10.123:3000) . I hope this gives you an idea for another approach.
Charlie
Hi, Charlie,
there is no way to run correctly my script.
I try to reinstall python shell but as the first installation, it seems to don't work:
root@edison:~# npm install python-shell
/home/root
npm WARN ENOENT ENOENT, open '/home/root/package.json'
npm WARN EPACKAGEJSON root No description
npm WARN EPACKAGEJSON root No repository field.
npm WARN EPACKAGEJSON root No README data
npm WARN EPACKAGEJSON root No license field.
I used the code posted but I have the same error of my original script:
If I want to modify the permissions of the test.py, where is loaded on Intel Edison, in which directory?
Best regards.
Giuseppe.
Hi Giussepe,
I was able to replicate your issue, this is only happening while using the XDK, if you use the Linux Terminal the error doesn't come up.
I tried changing the package.json in order to install the dependencies, no success
"name": "blankapp",
"description": "",
"version": "0.0.0",
"main": "main.js",
"engines": {
"node": ">=0.10.0"
"dependencies":{
"express": "=4.13.3",
"socket.io": "=1.3.7",
"python-shell":"=0.2.0 "}
I added the index.html and test.py in /home/root/.node_app_slot, then I ran the code with the XDK, no success
I haven't been able to remove the error while using the XDK, it seems that the xdk-daemon is not able to open python to run the code while running the JS script.
An alternative could be to use the Linux Terminal. If you open a session and go to a folder where the main.js, index.html and test.py are located you will be able to run node main.js without errors.
Charlie
