Dear Sirs,
I have an S5500BCR with already purchased 4 GB ram 1066MHz kit of 2, wondering if i add another 8 GB same 1066MHz kit of 2, will i get 12 GB and what is the correct configuration ???
If you have one processor installed, populate all 4 slots of that processor. If you have both processors installed, populate the 4 blue slots.
See http://www.intel.com/support/motherboards/server/s5500bc/sb/CS-030217.htm S5500BC TPS, section 3.2 for details.
& please use http://www.intel.com/support/motherboards/server/s5500bc/sb/CS-030211.htm tested memory ...
alright i checked and both kits are supported (KVR1066D3E7SK2-4GI & KVR1066D3Q8R7SK2-8GI), Scenarios tried:
1- 6 GB for the first CPU and 6 GB for the second through Blue slots, i got beeped
2- 6 GB Blue and Black for each CPU, i got beeped
3- Both kits work separately with no problem, but dont work together, i noticed a difference in ranks, so there is my problem, right ??
I checked your DIMM specs, and noticed you're mixing UDIMM and RDIMM, which is not supported. That's why you got beeps.
![](/skins/images/2F496A9BF2E73260E2FDFDBCABF91248/responsive_peak/images/icon_anonymous_message.png)
