Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4653 Discussions
Memory copy using Intel QuickData Technology
VJakh
I am doing the experimentation on improving the memory-to-memory copy performance (NIC to memory also, but secondary). I have seen that Intel I/OAT provides the Quickdata technology feature to offload the copies using DMA engine.
1. I haven't seen many i/oat related discussions in past few years, is it replaced with other more improved technology in new chipsets?
2. I need the Quickdata technology feature, how can I detect that my processor has Quickdata technology? In lspci, it is not showing anything related to Intel Quickdata Technology.
3. Which latest system/server should I buy to get the Quickdata Technology feature? If you can tell about NIC to memory copy (similar to TCP/IP offloads in i/oat), that will be very helpful.
Many thanks in advance.
Daniel_O_Intel
It looks like it's based on the chipset, not the processor - http://www.intel.com/support/network/adapter/pro100/sb/CS-023725.htm http://www.intel.com/support/network/adapter/pro100/sb/CS-023725.htm
The latest servers and systems are *not* listed on that page, so it is possible that Quickdata will not be present or supported on new servers.
