Hi
I am trying to run 4th Gen processor I3 4130 with server board R1200V3RP server family board ,but server beeps and does not boot.Please advice.
How many beeps are you getting, and what is the pattern? http://www.intel.com/support/motherboards/server/sb/CS-031822.htm Server Products — Not all beep codes signal an error. There is also a short list of POST Error Beep Codes in the TPS, page 250 (264 of 270), at http://www.intel.com/support/motherboards/server/sb/CS-034196.htm Server Products — Technical product specification.
Hi Dan,
Thanks for the reply,i solved the issue by changing the power supply with 8 pin connector,previously i was using 4 pin connector.
