Hi willie83, it took me a while to find why this is happening.
This Intel® Server Board uses the SMI LynxEM4+ graphics controller instead of Intel® HD Graphics.
Drivers are available for the operating systems listed here: https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21299 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21299
Let me know if you have further questions about the Intel® Server Board, I can try moving this discussion to the Intel Server Community if needed.
Hi willie83, this processor includes Intel® HD Graphics.
I am adding the download links for the exe installer and the instructions for the manual installation method using the zip driver file.
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22521 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22521
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22520 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22520
http://www.intel.com/support/graphics/sb/CS-033916.htm Desktop graphics drivers — How to Manually Install a Driver in Microsoft Windows 8* or Windows 8.1*
Thanks for the response back Joe.
I have tried to load that driver manually, but the problem is in the device manager, it says I have a Standard VGA graphics adapter, and when I try to install the driver it won't even give me the option to choose that driver. Is there a set of motherboard drivers that I need to instal first so the Intel HD adapter will show up?
Also, if I try to run the driver directly, it says the "computer does not meet minimum requirements for installing the software".
Install Language: English (United States)
System Locale: English (United States)
Installed: 6/4/2014 11:56:02 AM
Boot Mode: BIOS (http://www.belarc.com/secureboot.html Secure Boot not supported) Intel Corporation S3420GPV
Enclosure Type: Server ChassisProcessor a Main Circuit Board b3.07 gigahertz Intel Core i3 540
64 kilobyte primary memory cache
256 kilobyte secondary memory cache
4096 kilobyte tertiary memory cache
64-bit ready
Multi-core (2 total)
Hyper-threaded (4 total) Board: Intel Corporation S3420GPV E80883-106
Serial Number: AZGV04900496
Bus Clock: 133 megahertz
BIOS: Intel Corp. S3420GP.86B.01.00.0047.111620101731 11/16/2010
I'm beginning to think this motherboard, Intel S3420GPV, doesn't support the core i3 integrated HD graphics. Can anyone confirm?
I have updated the BIOS to the latest version
Thanks Joe,
Am I right in thinking that I'm stuck with the generic video adapter if I use this motherboard and windows 7? The operating systems listed are Linux and Windows Server 03 and 08.
EDIT: I just downloaded the driver and see that the Widows Server package contains windows 7 drivers.
If you would like to move this to the server forum, I do have another question.
I have loaded the driver and it is working better than the generic, but is there any way to assign more RAM to the video adapter?
I currently only have a measly 8 MB dedicated to the video adapter.
Thread will be moved as requested.
Joe.
