Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
4502 Discussions
My Pentium 4 processor reaching 89-94C
From few weeks my computer is working very slow i.eLagging very badly.No viruses detected then also i had formated the PC,but it was useless.Even if i open 2 small application at a time the C.P.U starts showing 100% usage and start lagging(work really very slow).Then i downloaded a application SpeedFan which showed temp of CPU 93 C.I applied thermal paste which was useless.Yesterday i thought that appln might be wrong so i watch the temp in BIOS which also showed me 88-93 C.Pls tell me reason abt such high temp and solution to my problem which is making my PC very slow .I've inserted img below.
My PC Configuration is :Microsoft Windows XP Professional Version 5.1.2600 Service Pack 2 Build 2600
System Manufacturer Gigabyte Technology Co., Ltd.
System Model 945GCM-S2L
System Type X86-based PC
Processor x86 Family 15 Model 4 Stepping 9 GenuineIntel ~2666 Mhz ( Pentium 4 ) SL number :SL 8PL
BIOS Version/Date Award Software International, Inc. F6, 12/27/2007
SMBIOS Version 2.4
Total Physical Memory 2,048.00 MB
Daniel_O_Intel
First, I would Enable the warnings. It looks like one or more of your cooling components are failing.
Did you put in the CPU and chassis fans yourself, or did they come preinstalled from Gigabyte?
Thanks for your reply.
As you had asked , I got my PC assembled from a guy who works Comp repairing,Assemling etc.
Daniel_O_Intel
The system fan shows that it's not plugged in - 0 RPM. I'd call the guy who built this first, and make sure he installed the right heatsink/fan combo for both the processor, and the chassis.
What is System Fan ?As i bought my PC i never added any component.Before it was fine what happen now.
Daniel_O_Intel
"System fan" is the fan inside the chassis. It's supposed to be spinning.
Really Sorry for late Reply !
I was busy in college 4 submission of files etc..
In my System there is only one fan i.e CPU FAN. I think it is not related with system fan because it was working fine till now as i didnt added any component.
Daniel_O_Intel
Your computer case (chassis) doesn't have any fans installed, besides one CPU fan?
That is bad news, my friend.
But It was working fine before what happen now . Is my processor is damage ? Pls solve my problem
Daniel_O_Intel
Both your processor and your motherboard are in danger of being damaged, without proper fan usage.
I highly encourage you to talk to whomever built your system, as it does not sound like a proper build to me.
Sir, I did'nt got it .I m using my PC from last 3 yrs till it was fine .What abt fan problem should i connect one more fan for chassis and also is my CPU fan is not working properly ?How should i know whether my CPU fan is damage ?
What should b the CPU fan speed ?
Daniel_O_Intel
It has been running until now, but every time you use it, there is a little more heat damage, until it gets serious problems.
I would not recommend running this without a fan chassis, possibly two depending on how bad off it is.
CPU fan speed looks fine. It's the chassis / system fan that is the problem.
