Scratching my head on this one and I've run out of things to try:
Windows XP Pro SP3
two single port PRO/1000 GT Desktop Adapters
Running latest drivers and PROSet installed
ANS tab is visible but when attempting to create a "New Team" the "No Intel server adapter or Intel integrated connection is available for teaming." messages pops up. Can't even create a single NIC team, basically no compatible adapters discovered. (doesn't the 1000 GT DEsktop support teaming?)
Have ensured all TCP/IP offloading features are turned off and both adapters are configured identical.
Have uninstalled, rebooted and reinstalled drivers and PROSet as well, with ame results: temaing finds no adapters at all, noit even the LOM.
The motherboard is an ASUS M4N78PRO with and AMD Phenom 9600 quad-core. BIOS updated to latest release.
Was thinking AMD equivalent to AMT to turn off but nothing found on this.
Anyone can provide some help?
-r
Teaming options are supported on Intel desktop adapters if there is at least one server adapter installed. For more details about teaming and ANS, check http://www.intel.com/support/network/sb/cs-009747.htm http://www.intel.com/support/network/sb/cs-009747.htm
As I like to say, "the devil is in the details". Thanks Edward, figured it was something like that .... missed that one.
-r
