Hello, I have Motherboard S5520SC e two processors e5620, 8 GB ram Kingston compatible as a compatibility list and a chassis SC5650 Intel.
I've assembly all yesterday but when i try to power the system nothing appears on the screen (black) and the chassis fans are on the max power.
Box starts all fans and nothing after that. No graphic/no beeps/no any actions. The processor is listed compatible with my motherboard only with the BIOS 46, how to update the bios without any screen? I need to change the two processors? Is not possible to update in other mode or to force the system bios to load?
Thanx in anvance. All answer are welcome, in the forum or in my email giginhq@gmail.com
GG
Check http://www.intel.com/support/motherboards/server/sb/CS-031498.htm http://www.intel.com/support/motherboards/server/sb/CS-031498.htm - the refresh boards are flashed with BIOS that supports Xeon 5600 series in factory. However, if you have a non-refresh board, you'll have to use a Xeon 5500 series to boot it up and upgrade to BIOS 48 or later.
Hello, thank for Yor reply.
I will try....
GG
