Currently we have an Intel server that is about 5 years old with the following specs:
System ModelWindows Server 2003 StandardEdition Service Pack 2 (build 3790) Intel
Enclosure Type: Server ChassisProcessor a Main Circuit Board b3.00 gigahertz Intel Pentium 4 (2 installed)
16 kilobyte primary memory cache
1024 kilobyte secondary
memory cache Board: Intel SE7520JR23D FRU Ver 0.01
Serial Number: BZJR60100827
Bus Clock: 800 megahertz
BIOS: Intel Corporation SE7520JR23.86B.P.10.00.0087.120820051348
12/08/2005Drives Memory Modules c,d
319.98 Gigabytes
Usable Hard Drive Capacity
244.94 Gigabytes Hard Drive Free
Space
Slimtype COMBO SOSC-2483K [CD-ROM drive]
MEGARAID LD 0 MEGARAID SCSI Disk Device (159.99 GB) -- drive 0
MEGARAID LD 1 MEGARAID SCSI
Disk Device (159.99 GB) -- drive 1 2048 Megabytes Installed
Memory
Slot 'DIMM 1A' has 1024 MB
Slot 'DIMM 1B' has 1024 MB
Slot
'DIMM 2A' is Empty
Slot 'DIMM 2B' is Empty
Slot 'DIMM 3A' is Empty
Slot
'DIMM 3B' is Empty
What would be a compatible server that would have simiar specs? It would definitely need to have two fixed hard drives and 2 processors
That server is at least 5~7 years old, and a lot have changed... Your server is a rack-optimized system. In current generation there are two rack-optimized server boards. Below is a quick comparison:
http://ark.intel.com/compare/61039,56253 http://ark.intel.com/compare/61039,56253
Do you have a requirement for WS2003 OS (32-bit i think) on it? Cause there are some troubles with old MS server OSes on latest server platforms, which may hurt sysadmin work by some. If you can upgrade to WS2008/R2, you should not encounter such quirks.
![](/skins/images/8B5EA638CA3587CA763EE9EF53643DD4/responsive_peak/images/icon_anonymous_message.png)
