Good evening
I have a problem with my server board s1200btlr.
It worked but now it can't start :
There are 5 beep code and LEDs diagnostic code is : 1111 1001 (LED 7 to 0)
This LEDs diagnostic is not refere in the documentation.
No screen, I tried a clear CMOS but again it doesn't start.
Thank's for help
The first thing to test is, try removing everything but the CPU, and see if you get three beeps. Then you can start working through the tool posted to http://www.intel.com/support/motherboards/server/sb/CS-029657.htm http://www.intel.com/support/motherboards/server/sb/CS-029657.htm - it will walk you through how to test the basic functions, then move up to the more complex things.
![](/skins/images/E799062D82CA2A220ED12C6FD1960495/responsive_peak/images/icon_anonymous_message.png)
Topic Options
