Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4657 Discussions
RAID: After that, I'm trying to install Windows 2008 R2, but the initial level is loading from the installation disk, and then drastically goes into reboot.
АПодл
Good afternoon Dear experts!
I had the following problem, and I can not figure out what it is related to.
I use the S5500BC motherboard, to which the RAID controller RS2BL080 is connected in the quantity of 1 pc.
This RAID controller worked on SATA HDD in the amount of 6 pcs.
After 1200 days of HDD operation, the OS with RAID ceased to run.
I checked the SATA HDD and they are all working.
I created a new RAID configuration of 1 or 0.
After that I succeeded, where it is written that VD0 is created and online.
What is the reason for this?
The BIOS has RAID boot enabled.
Can you help with this issue?
