Either I'm so unlucky or it's common trouble for RS2BL040. Or a certain firmware. Can someone suggest?
2 Intel servers with the same configuration and software in a different contries from different supplyers
I just never use Intel raid controllers before and after. Only LSI or Adaptec. Never seen BBU fault. It was my first time.
I see the servers perfomance degrade this month. Just write cache switched off.
This is the BBU after 2-2.5 years of usage. Both the same:
# /opt/MegaRAID/MegaCli/MegaCli64 -AdpBbuCmd -aall
BBU status for Adapter: 0
BatteryType: iBBU
Voltage: 3851 mV
Current: 0 mA
Temperature: 22 C
BBU Firmware Status:
Charging Status : None
Voltage : OK
Temperature : OK
Learn Cycle Requested : No
Learn Cycle Active : No
Learn Cycle Status : OK
Learn Cycle Timeout : No
I2c Errors Detected : No
Battery Pack Missing : No
Battery Replacement required : Yes
Remaining Capacity Low : Yes
Periodic Learn Required : No
Transparent Learn : No
Battery state:
GasGuageStatus:
Fully Discharged : No
Fully Charged : Yes
Discharging : Yes
Initialized : Yes
Remaining Time Alarm : No
Remaining Capacity Alarm: No
Discharge Terminated : No
Over Temperature : No
Charging Terminated : No
Over Charged : No
Relative State of Charge: 98 %
Charger System State: 49168
Charger System Ctrl: 0
Charging current: 0 mA
Absolute state of charge: 34 %
Max Error: 2 %
BBU Capacity Info for Adapter: 0
Absolute State of charge: 34 %
Remaining Capacity: 416 mAh
Full Charge Capacity: 424 mAh
Run time to empty: Battery is not being discharged
Average time to empty: Battery is not being discharged
Average Time to full: Battery is not being charged
Cycle Count: 37
Max Error: 2 %
Remaining Capacity Alarm: 120 mAh
Remaining Time Alarm: 10 Min
BBU Design Info for Adapter: 0
Date of Manufacture: 11/25, 2010
Design Capacity: 1215 mAh
Design Voltage: 3700 mV
Specification Info: 33
Serial Number: 11218
Pack Stat Configuration: 0x64b0
Manufacture Name: LS1121001A
Device Name: 3150301
Device Chemistry: LION
Battery FRU: N/A
BBU Properties for Adapter: 0
Auto Learn Period: 2592000 Sec
Next Learn time: 426469127 Sec
Learn Delay Interval:0 Hours
Auto-Learn Mode: Enabled
BatteryType: iBBU
Voltage: 3908 mV
Current: 0 mA
Temperature: 26 C
Voltage : OK
Temperature : OK
Battery state:
GasGuageStatus:
Fully Charged : Yes
Discharging : Yes
Initialized : Yes
Over Charged : No
Absolute state of charge: 32 %
Max Error: 2 %
Absolute State of charge: 32 %
Remaining Capacity: 391 mAh
Full Charge Capacity: 398 mAh
Cycle Co...
- Tags:
- Intel® RAID RS2
- RAID
AOZ,
The BBU Firmware Status of "Battery Replacement required" seems to indicate the BBU has failed.
John
