After a power outage, the Web Console 2 lists all my drives as Foreign Unconfigured Bad.
I am using controller RS2WC080, with 5 WD 1TB drives in RAID 5 config on a single virtual drive.
Is this recoverable?? Did I lose all my data??????
Please help!
/b
Figured it out! Wanted to post my answer in case it help someone else one day...
I may not be 100% accurate in my representation, but basically the configuration is written to both the controller and to the drives.
So here's what I did:
- I flipped all the drives from "Foreign, Unconfigured Bad" to "Foreign, Unconfigured Good".
- Scanned the Foreign configuration, verified that it was correct
- Accepted the configuration
- Ran consistency check
And that's all it took. Data is back, array is Optimal, and im breathing easy.
whew.
/b
whew.
/b
