Hello Team!
I'm looking for compability list Intel Raid Controller RS3DC080.
I wanna got what kind of new SSDs are compabilited with RS3DC080.
I need replace old SSDs to large volume SSDs.
Thank you in advance!
Thank you a lot! But I can see this document is old and these SSDa are not "live" and no longer shipped.
Hi Mikhail,
I Hope you are doing well today.
I apologize for my late response.
I got new information in regards to the RAID controller and the compatible Drives for the same.
It seems like, there are no new launches of Tested Hardware and Operating System Lists for this RAID controller; therefore, the supported drives are based on what the Intel Server Systems where the card is installed in supports. If the RAID controller is not in an Intel(R) Server System, but in a third Party Server System, then, the drive support would be on the OEM third party site.
I hope this information helps to clarify your inquiry.
If you have any question, do not hesitate in replying to this post; more than glad to help.
Jeremiah A.
Under Contract to Intel Corporation
Hi Mikhail,
I have not heard back from you in regards to this request.
I was wondering if the information provided earlier helped or you have any question or concern.
Looking forward to your comments.
Jeremiah A.
Hi Jeremiah,
Thank you so much for the answer.
I got it. I will to apply SuperMIcro motherboard's datasheet.
But I don't have sure that it's correct, because I will to apply data regarding embedded SuperMico RAID-conroller, and use Intel Raid-controller.
I am having an issue as the datasheet is not getting opened and the thing is that I have also having an issue on the module as it is not being accessed through the data sheet and I was doing it on the Windows CMD module to look what will be the effect of it. It did create a problem on the Microsoft compatibility telemetry high disk and I really do not know how can I fix it.
Hi Mikhail Kozlov,
Please let us know if there is anything else that we can assist you with.
Looking forward to you comments.
Jeremiah A.
Hi Mikhail Kozlov,
I hope you are doing well today.
I haven't heard back from you in regards to this case. I will proceed in closing the same. If you need more assistance or have more questions or concerns do not hesitate in replying to this post; more than glad to assist.
Jeremiah A.
