Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4616 Discussions
Recently purchased Intel SS4200-EHW
I have recently purchased a SS4200 (refurbished) It arrived without, Memory, a power cord and the DOM (Which i am not sure I should get with a EHW. The question I have is 2 fold, (and if I am posting this in the wrong location please move to the appropriate place i would appreciate it).Should a SS4200-EHW come with a power cord, memory and a DOM? And yes :-) I understand the terms of "unless other wise specified". and if it if the EHW does not come with a DOM or "might not" in my situation, then is it possible to use a 2.5 laptop drive, with an adapter of course and plug to the blue pata controller ? Using this as a standard 2.5" IDE drive? I hope someone can answer my question.
Many Thanks
Endless
Endless,
The EHW (Hardware Only) SKU does not include the DOM. The DOM contains the EMC software that's provided with the SS4200-E SKU. Both the EHW and E SKUs provide a 512MB memory DIMM. The SS4200-EHW is intended by Intel for Windows Home Server installation only:
http://www.intel.com/support/motherboards/server/ss4200ehw/sb/CS-028981.htm http://www.intel.com/support/motherboards/server/ss4200ehw/sb/CS-028981.htm
Windows Home Server is installed on the installed 3.5" SATA HDDs. Intel hasen't tested any boot devices other than the EMC DOM (E SKU) or installed 3.5: HDDs (EHW SKU), so can't provide any help with the method you describe.
John
