I have a S1200BTL board and I cannot find any information what processor/memory combination can give me Double Channel (with all memory slots occupied).
Our client has a Intel XEON E3-1275 on this board but not even with 2 KVR1333D3E9S/4GI on the dual channel slots can we get them to work. BIOS always shows memory as "Intependent".
So I need a processor model that supports double channel.
See page 20 (32 of 153) in the TPS at http://www.intel.com/support/motherboards/server/sb/CS-032382.htm http://www.intel.com/support/motherboards/server/sb/CS-032382.htm - it covers the population rules
Thanks, but I have populated all the memory slots correctly.
My problem is that it is still appearing (in BIOS) to be working in "Independent" memory config.
You reckon it is not a CPU related issue?
What is your BIOS version? If it's older than 30, try the latest version here: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=20655 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=20655
Indeed I reckon the version is 28 (since I do not have access to the machine at the moment). But I do not see any info in the release notes about that issue (in versions above 30). I will perform a BIOS update as soon as I can, and report back.
Just checked the firmware: latest version of BIOS (and BMC/ME/FRUSDR) installed - version 30.
Problem is the system still does not use memory modules in dual-channel. Not even when only 2 memory modules are installed.
Current configuration has an Intel Xeon E3-1240 installed, and 4 memory modules KVR1333D3E9S/4GI (Intel validated).
So why is it not working in dual-channel mode?
FYI: The issue is caused because of a BIOS display bug. It seems that memory dimms work in dual channel, but that info is not displayed in BIOS.
Should be remembered for further reference.
Cheers
