Using S1200BTL KVM (RMM4) to remotely control server - I'm unable to enter bios using F2 key.
Everything else works fine - I have integrated RAID module - LSI utility is accessible using Ctrl+C, when system boots into EFI keyboard works fine.
If I try to enter bios localy F2 works fine.
I tried hitting F2, holding F2, even tried software keyboard.
I believe I run latest bios, firmware and etc.
Where is the catch ?
thanks
Vilius
Ok, increasing "System Boot Timeout" bios setting solved the problem.
Supposedly default time value is too short for remote usage.
V
