Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4545 Discussions
S1200BTSR POST Error
jjepp1
I have just put together a system, but it does not get past post.
Error leds indicate 0x15 North Bridge PEI Module Starts.
All parts are new.
MB: S1200BTSR
CPU: I3-3220 (BX80637I33220)
RAM: KVR1333D3E9SK2/16G ( 32GB 2x kits of 2x8gb sticks)
PSU: ATX v2.3 750w
I have tested all different RAM configs, and other type of RAM without any success. Always end up with 0x15 (xxxO xOxO)
If I boot without any RAM Modules I get RAM error Beep Codes.
Also tried to remove everything connected to the board, but still same error.
Any ideas on what it might be?
Edward_Z_Intel
Select memory from the http://www.intel.com/support/motherboards/server/sb/CS-032418.htm Tested memory and hardware list.
