Hello
I apologize in advance for the presentation of the text, write in Russian and translate in the browser.
Asking for help from professionals. Platform "R1304SPOSHBN", fully assembled, all components are in their places, the processor is "XEON E3-1230 v6 ", RAM 2*16GB Kingston KVR24E17D8/16MA
The problem is that when the system starts the testing begins, the fan speed maximum rpm is reduced to minimum and testing apparently ends, then should start to boot the system (?), however on the screen nothing appears either during testing or after. However, after the fall of the fan speed, about 30 seconds later the server rebooted, then again and again. The screen is totally unresponsive. Apparently the problem with the built-in graphics card, but connecting the external new and serviceable graphics card has not produced results. BIOS reset.
In this case, can advise? How to diagnose the problem? The server is brand new, probably made a mistake somewhere with the connection of the components, but did everything according to instructions.
Help Board!
Hi Nevidimka,
The Intel® Server Board S1200SPO is compatible with the Intel® Xeon® Processor E3-1230 v6; however, this processor was released after the board; so it is necessary to update the BIOS of the board to version 02.01.0049 at least using an Intel® Xeon® Processor E3-1200 v5.
The compatible processors are below
E3-1280 v5
E3-1270 v5
E3-1260L v5
E3-1240L v5
E3-1240 v5
E3-1230 v5
E3-1220 v5
The BIOS version needed is the following.
https://downloadcenter.intel.com/download/26525/Intel-Server-Board-S1200SP-Firmware-Update-Package-for-EFI?product=88264 Intel® Server Board S1200SP Firmware Update Package for EFI
If you need further assistance please let me know.
Mike C
Thanks for the advice! I'll try to update and write the result.
Hi Nevidimka,
Sure, I would be waiting for your answer.
Regards,Mike C
Hi Nevidimka,
I am following your case, please let me know if you need further assistance.
Mike C
