Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4613 Discussions
S1200V3RP is compatible with KVR 13G9/8I and KVR 13R94L/8 ?
AMota2
Hello, I have an Intel Server Board model S1200V3RP and need to know if is compatible with these memories: KVR 13G9/8I KINGSTON and KVR 13R94L/8 KINGSTON
David_A_Intel
I could not locate these part numbers in our http://www.intel.com/support/motherboards/server/sb/CS-034302.htm Tested Hardware and Operating System List for this board. Intel always recommends using validated components to avoid unforeseen issues.
I am including the specifications that the memory modules need to meet for the board.
GKlug1
Hello Igor-Mota,
this is no regular Kingston Memory identification (found on http://www.kingston.com/de/memory/valueram/valueram_decoder ValueRAM Decoder ) so i suggest to use not that memory.
Like David_Intel mentioned before the S1200V3RP Boards accept only unbufffered DDR3L ECC Memory (UDIMM) in Single Rank or Dual Rank (DDR3L are Low Voltage Memory that runs with 1.35V instead of 1.5V).
Here you finde the http://www.intel.com/support/motherboards/server/sb/CS-034196.htm Server Products — Technical Product Specification for the R1200V3RP, that should help you decide what kind of Memory to use.
If you could post a good picture from your Memory, maybe i can give you more information.
