I loaded a server S1200BTL and installed 2 drives Raid 1. Device Manager shows Storage Controllers->Intel Desktop/Workstation/Server Express Chipset SATA Raid Controller.
Windows Server 2008 R2 Foundation sp1 (64 bit).
I am trying to get the management program/utility for this raid system but have had no luck. The Raid Web Console 2 does not see the controller which leads me to believe that is the wrong utility.
Can someone point me to the correct download? All works well. I just need the Intel Storage Manager or whatever it is called now days to alert to a drive issue and be able to manage the Raid.
Hi DougSatt,
you wind all correct Drivers and other Downlaods for you S1200BTL here https://downloadcenter.intel.com/product/61077/Intel-Server-Board-S1200BT https://downloadcenter.intel.com/product/61077/Intel-Server-Board-S1200BT . The actual Intel Raid Web Console 2 are (23.07.2015) here https://downloadcenter.intel.com/download/24745/RAID-WEB-Console-2-Utility-for-Windows- Intel® Download Center - its Version 14.11.01.00. Furthermore you should use the actual Firmware and the right Driver for your RAID Controller. Care that the Intel Raid Web Console 2 is an Intel Solution basend on LSI. So you can only manage Intel or LSI Raid Controllers and Volumes with this Solution.
If you use teh onboard RAID Solution you should now, that RST dont work with Intel RAID Web Console 2. Instead you could use the RST GUI: https://downloadcenter.intel.com/download/20110 Intel® Download Center.
Hi DougSatt,
![](/skins/images/D2683F18326913BBA0436CB7114DD569/responsive_peak/images/icon_anonymous_message.png)
