Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4613 Discussions
S1200V3RP won't boot
Server Board S1200V3RPL
CPU: XEON E3-1231 V3
Memory: Crucial DDR3-1600 ECC (2x8 GB)
Board does nothing - green LED showing power near the power connection on the motherboard lights up but nothing else. This is the second board that I have tried. Have also switched out the PSU in case that was the issue. No startup, no error codes, no beeps, nothing. Any ideas what I am doing wrong? Could I have gotten two bad motherboards? Any ideas on how to diagnose?
Thanks for reading!
Here are our recommendations:
1. Test the system without the processor installed looking for a 1-5-4-2 beep code sequence.
2. Test the system without memory installed looking for 3 regular beep codes.
3. Let us know the PBA number for the board you have. This can be found on a white sticker located on the board itself.
Thank you for the reply.
As you recommended:
1) removed processor - same result; green power LED on and no other activity, no beeps
2) removed processor and memory - same result; green power LED on and no activity, no beeps
3) PBA is G62251-407
Looking forward to next steps.
Thanks!
Please contact our support group directly for assistance on replacing the board under warranty:
http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport
