Hi, ticket number 6,
i removed all incompatible "products"
installed both CPUs
2x Intel XEON 6154 Gold
16x Samsung Samsung M393A4K40CB2-CTD
When i try to start this Server, all LEDs blinks permamently.
Whats next ?
i Tried it with one CPU all LED Error Codes your Board showing me are not valid on your Post Code Decoder Page.
FYI: I cant switch to another Board and i cant try different CPUs
What does it mean when all LEDs Blinks permamently ?
changed cpu installation fom 1 and 2 and back.
server said "beep beep" and nothing happend
what should i do ?
Hello iDustBin,
Thank you for joining the Intel community
Is this a brand new board/system or was it working before?
By any chance are you using a 3rd party chassis?
The initial suggestion is to try minimal configuration 1 CPU and 1 DIMM only
Try to set the BIOS recovery jumper into recovery mode
If all this fails we will be able to create a warranty replacement order
We will look forward to your updates
Jose A.
For firmware updates and troubleshooting tips, visit:
https://intel.com/support/serverbios
I tried to use bios recovery it doesnt work !
Its an Intel Chassie !
Server isnt working please send me a new board !
Hello iDustBin,
Thank you for the confirmation. We should be able to create a warranty order for this board. Since we will need some sensitive info like SN and shipping address, please go to Warranty Information (intel.com) and submit the information from there to generate a warranty case.
Jose A.
I cant find the SN on this Board, i also have absolutly no clue whats a Stocking ID.
Once again, i asked this question 3x times. until today i didnt get a correct answer !
