Installed latest BIOS, FRU, SDR & so on. Tried to change in BIOS - acousting section - no changes. Looked in sysinfo utility's log file - many strings about redundancy fan failure. But I have in this case only permanent fans with 4 wires instead of 6pinout. A part of log here:
System Information Retrieval Utility Version 12.0 Build 10
Copyright (c) 2013 Intel Corporation
Platform Firmware Inventory
BIOS Version....... SE5C600.86B.02.01.0002
BMC Firmware Version:
Op Code....... 1.19.5018
Boot Code.............. 01.17
ME Firmware Version:
Boot Code: 02.01.07.231
SDR Version:
SDR version: SDR Package 1.10
Sensors
LUN NAME NUMBER OWNER UNITS VALUE
0 Fan Redundancy 12 32 REDUNDANCY_LOST, NON_REDUNDANT_INSUFFICENT_RESOURCES
0 SSB Therm Trip 13 32 STATE_DEASSERTED
0 BMC FW Health 16 32 UNKNOWN
0 System Airflow 17 32 CFM 150.000000
0 BB EDGE Temp 32 32 Degrees Celsius 25.000000
0 Front Panel Temp 33 32 Degrees Celsius 26.000000
0 SSB Temp 34 32 Degrees Celsius 43.000000
0 BB BMC Temp 35 32 Degrees Celsius 34.000000
0 BB P2 VR Temp 36 32 Degrees Celsius 36.000000
0 BB MEM VR Temp 37 32 Degrees Celsius 29.000000
0 Pwr Unit Status 1 32 ALL_DEASSERTED
0 LAN NIC Temp 47 32 Degrees Celsius 41.000000
0 System Fan 1 48 32 RPM READING_UNAVAILABLE
0 System Fan 2 49 32 RPM READING_UNAVAILABLE
0 System Fan 3 50 32 RPM READING_UNAVAILABLE
0 System Fan 4 51 32 RPM READING_UNAVAILABLE
0 System Fan 5 52 32 RPM READING_UNAVAILABLE
0 Fan 1 Present 64 32 DEVICE_REMOVED/DEVICE_ABSENT
0 Fan 2 Present 65 32 DEVICE_REMOVED/DEVICE_ABSENT
0 Fan 3 Present 66 32 DEVICE_REMOVED/DEVICE_ABSENT
0 Fan 4 Present 67 32 DEVICE_REMOVED/DEVICE_ABSENT
0 IPMI Watchdog 3 32 OK
0 Fan 5 Present 68 32 DEVICE_REMOVED/DEVICE_ABSENT
0 P1 Status 112 32 PROCESSOR_PRESENCE_DETECTED
0 P2 Status 113 32 PROCESSOR_PRESENCE_DETECTED
0 P1 Therm Margin 116 32 Degrees Celsius -48.000000
0 P2 Therm Margin 117 32 Degrees Celsius -48.000000
0 P1 Therm Ctrl % 120 32 % 0.000000
0 P2 Therm Ctrl % 121 32 % 0.000000
0 P1 ERR2 124 32 STATE_DEASSERTED
0 P2 ERR2 125 32 STATE_DEASSERTED
0 CATERR 128 32 STATE_DEASSERTED
0 Physical Scrty 4 32 GENERAL_CHASSIS_INTRUSION
0 P1 MSID Mismatch 129 32 STATE_DEASSERTED
0 CPU Missing 130 32 STATE_DEASSERTED
0 P1 DTS Therm Mgn 131 32 Degrees Celsius -49.000000
0 P2 DTS Therm Mgn 132 32 Degrees Celsius -48.000000
0 P2 MSID Mismatch 135 32 STATE_DEASSERTED
0 P1 VRD Hot 144 32 LIMIT_NOT_EXCEEDED
0 P2 VRD Hot 145 32 LIMIT_NOT_EXCEEDED
0 P1 MEM01 VRD Hot 148 32 LIMIT_NOT_EXCEEDED
0 P1 MEM23 VRD Hot 149 32 LIMIT_NOT_EXCEEDED
0 P2 MEM01 VRD Hot 150 32 LIMIT_NOT_EXCEEDED
0 FP NMI Diag Int 5 32 OK
0 P2 MEM23 VRD Hot 151 32 LIMIT_NOT_EXCEEDED
0 DIMM Thrm Mrgn 1 176 32 Degrees Celsius -58.000000
0 DIMM Thrm Mrgn 2 177 32 Degrees Celsius READING_UNAVAILABLE
0 DIMM Thrm Mrgn 3 178 32 Degrees Celsius -59.000000
0 DIMM Thrm Mrgn 4 179 32 Degrees Celsius READING_UNAVAILABLE
0 Mem P1 Thrm Trip 192 32 OK
0 Mem P2 Thrm Trip 193 32 OK
0 Agg Thrm Mgn 1 200 32 Degrees Celsius -24.000000
0 Agg Thrm Mgn 2 201 32 Degrees Celsius -24.000000
0 Agg Thrm Mgn 3 202 32 Degrees Celsius -23.000000
0 SMI Timeout 6 32 STATE_DEASSERTED
0 Agg Thrm Mgn 4 203 32 Degrees Celsius -23.000000
0 Agg Thrm Mgn 5 204 32 Degrees Celsius -24.000000
0 BB +12.0V 208 32 Volts 11.883000
0 BB +5.0V 209 32 Volts 4.937100
0 BB +3.3V 210 32 Volts 3.282000
0 BB +5.0V STBY 211 32 Volts 4.980500
0 BB +3.3V AUX 212 32 Volts 3.282000
0 BB +1.05V P1Vccp 214 32 Volts 0.911700
0 BB +1.05V P2Vccp 215 32 Volts 0.887700
0 BB +1.5 P1DDR AB 216 32 Volts 1.495400
0 System Event Log 7 32 UNKNOWN
0 BB +1.5 P1DDR CD 217 32 Volts 1.509000
0 BB +1.5 P2DDR AB 218 32 Volts 1.509000
0 BB +1.5 P2DDR CD 219 32 Volts 1.502200
0 BB +1.8V AUX 220 32 Volts 1.793600
0 BB +1.1V STBY 221 32 Volts 1.076230
0 BB VBAT 222 32 Volts 3.055900
0 BB +1.35 P1LV AB 228 32 Volts READING_UNAVAILABLE
0 BB +1.35 P1LV CD 229 32 Volts READING_UNAVAILABLE
0 BB +1.35 P2LV AB 230 32 Volts READING_UNAVAILABLE
0 BB +1.35 P2LV CD 231 32 Volts READING_UNAVAILABLE
0 System Event 8 32 UNKNOWN
96 NM Capabilities 26 44
96 P1 MTT 52 44 %
96 P2 MTT 53 44 %
0 Button 9 32 UNKNOWN
0 VR Watchdog 11 32 STATE_DEASSERTED
Seems the BMC can't get any fan readings. Which fan connectors are you using?
Your chassis has two fixed fans, and they should go to Sys Fan 1 and Sys Fan 2.
![](/skins/images/D3C0B914909A6564BBB97F4AD1ED1973/responsive_peak/images/icon_anonymous_message.png)
