Good Thursday everyone,
I am setting up another server, Intel S2600STBR motherboard with a single Gold 6130T processor. I have DDR4-2400 ECC RAM, will that RAM work or do I need to use DDR4-2666 RAM?
Ray
Hello RSump1,
Thank you for joining the Intel community
According to ark.intel.com this S2600STBR boars supports the following memory types: DDR4 ECC RDIMM/LRDIMM 2133/2400/2666/2933 (Intel® Server Board S2600STBR Product Specifications) . Even though the Technical Product Specification document (https://www.intel.com/content/dam/support/us/en/documents/server-products/Intel_S2600ST_TPS.pdf#page=48) specifies that, for this processor/RAM combination, the supported types are 2666-2933 if you want to achieve the maximum possible speed out of the system. I think its possible to install DDR4-2400 and making the system to boot, but, since this is not a recommended configuration you might experience slow performance and/or random RAM related issues.
If you want to verify if the RAM you already have it is validated or not you can check the Intel Server Configurator Tool Current Gen THOL (intel.com)
I will look forward for your comments
Jose A.
Hello RSump1,
I am just following up to double-check if you found the provided information useful. If you have further questions please don't hesitate to ask. If you consider the issue to be completed please let us know so we can proceed to mark this thread as closed. I will try to reach you as a very last time on next Thursday 28th. After that we will mark the thread as closed
Jose A.
Hello RSump1,
We will proceed to mark this thread as closed. If you have further issues or questions just go ahead and submit a new topic.
Jose A.
