I am looking at using the S2600TPR board for a project and I have a few questions:
1. Can all 4 riser slots be used as a PCIe expansion slot or have a riser card to make a PCIe expansion slot?
2. Can the mezzanine port be converted to a PCIe expansion slot?
3. Does the Intel S2600TPR board support VMware ESXi?
Hello macrules34,
Answering your questions:
There are only 2 PCIe slots on this board allowing you to use only 2 riser cards. The riser cards are pass through only to the PCIe slot on the board.
The mezzanine port (I/O module carrier) supports both a SATA M.2 storage device and a 8x PCIe 3.0 devices. You can check the https://www.intel.com/content/dam/support/us/en/documents/server-products/H35763-003_S2600TP_HNS2600TP_TPS_R1_41.pdf Technical Product Specification document on page 18
The S2600TP family board does support VMware ESXi 6.5 at a basic installation and compatibility level. You can check this info on this https://www.intel.com/content/www/us/en/support/server-products/server-boards/000007872.html URL
Hope this helps
Jose H.
Hello macrules34,
Hope this helps
Jose H.
Jose,
I would like to use riser slots 1 & 2 for standard PCIe expansion slots what are the part numbers for the riser cards? I couldn't find them in the manual.
Hello macrules34,
The PCIe riser part number is:
PCI express riser FHW1U16RISER2.
You could get the spare parts number list from the following document: https://www.intel.com/content/dam/support/us/en/documents/server-products/server-boards/S2600TPR_HNS2600TPR_H2000G_Configuration_Guide_v2_1.pdf
Jose H.
Hello macrules34,
Do you have any updates about this.
Just let me know.
Regards.
Jose H.
Thats all the questions I have for now. Will post more if I have further questions. Thanks for your help.
Macrules34
Thanks Macrules34,
I will mark this thread as answered by now.
Jose H.
![](/skins/images/7B0AB6865064EAE32B30EC9A4E94B48A/responsive_peak/images/icon_anonymous_message.png)
