this is the error I get on the S2600WT2 - running the latest BIOS/FW stack as of 6/25/15
I can mount ISO no problem, and IMG, but having issues seeing the USB drive connected to my local PC
hopefully someone can assist, tired of walking to the lab
I've tried multiple USB sticks, my current one i want to use is 2GB, but have tried 4GB and 8GB models as well
also tried different USB ports on my system, both front and back
- Tags:
- USB General
USB stick fat32?
Do you see it on the windows host system?
if so all all files and folders closed so that the RMM can lock for exclusive access?
yes FAT32 - i can see it on the host, exclusive access...
i've used this flash drive on dozens of intel servers - but this model (or maybe firmware) is having this problem...
I have yet to find the offending setting yet, but some IT builds lock down the system so a remote web page cannot connect to a USB drive.
I am not sure if it is a registry setting, firewall setting or java setting.
I will update if i can figure out which.
![](/skins/images/8B5EA638CA3587CA763EE9EF53643DD4/responsive_peak/images/icon_anonymous_message.png)
