Server Products
4874 Discussions
S3420GP - Which RAID drivers for W2008 R2?
Hi-
I have been away from Intel servers for awhile. Decided I was tired of HP and Dell and I'd go direct again. I have this nice S3420GP server with a SSD and 2 x 2 TB drives. I get through the Server Deployment disk - and that's where I am stuck.
I am trying to install the OS on the SSD. I had a USB key in during the Server Deployment process and it added drivers to the USB key. I get to the point where I have to add a driver and it stops there. I've browsed to the USB Key and tested each of the drivers, I've put the server deployment disk and drfilled down to the drivers - and nothing seems to work.
What am I missing?
Jay
S3420GP Windows 2008 Server R2 Drivers
Here's the message I get after trying to install ESRT-2:
Any help here would be really appreciated...
Hi Edward-
Thanks for that - but we have already been down that road with multiple USB drives and a burned CD.
Any other ideas would be really helpful tonight...
Jay
Edward_Z_Intel
Did you create a RAID 0 VD on the SSD?
Edward_Z_Intel
Can you try to follow the steps in the two demos below:
http://www.intel.com/support/motherboards/server/sb/CS-029508.htm Demo: Configuring Intel® Embedded Server RAID Technology II
http://www.intel.com/support/motherboards/server/sb/CS-030677.htm Demo: Loading Intel® Embedded Server RAID driver during OS installation
Coconutdog
Did you initialise the RAID array? I think you also have to set it as bootable. I had no trouble installing Server 2019 on mine after I had the settings correct. I found that I had to go back into the ESRT2 (Ctrl-E) and reset and start again after my first attempt failed. Also latest BIOS (54) would be advisable.
