hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
Server Products
5007 Discussions
S5000XVN loses SAS RAID configuration every time I reboot
I am working on a server with S5000XVN Motherboard and I have setup the SAS drives as RAID 1. Everytime I reboot the the computer it loses the RAIN configuration and I have to recreat it. Any idea what I need to to to fix this?
JasonT_Intel
Interesting issue, have you checked for your firmware level on the board ? Latest update is available http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19610&ProdId=2308&lang=eng here. Also, check for the http://www.intel.com/p/en_US/support/category/server/s5000xvn/faq FAQs available here for storage related questions that may give you clues on what you are encountering.
I took your advise and updataed the firmware on the raid bios and that fixed the problem.
I've got the same problem :/ update don't solve problem
got the same problem... update's not solving the problem.. the wierd thing is that on the older version of BIOS everything worked just fine...
got the same problem.. the wierd thing is that on the old version of BIOS everything worked just fine... any sugestions?
