Server Products
Data Center Products including boards, integrated systems, RAID Storage, and Intel® Xeon® Processors
5051 Discussions
S5520HC + Firewire 1394 400
I need to expand my system with a Firewire 1394 port (i need the 400 port but is better if i have 400 and 800 ports). The PCIe is the only way or is possible to use other internal connections (like serial or other internal connectors....). I need a PCIe or is possible to connect any PCI device? what changes?
Can you advise me what to buy without spending much?
Thanx so much!
GG
Daniel_O_Intel
I don't see any Firewire cards on the list at http://serverconfigurator.intel.com/configure-ap.aspx?id=MTY2NCMxLDI1MTcjMSwyNjE4IzIsMjUzMyMx&ShowNavigation=false , so you'd probably have a hard time getting proper drivers.
