Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4917 Discussions
S5520UR 6 Gb/s Server
I am trying to configure a new SR1625UR server and I can't seem to figure out what parts I need to order to make a new SAS 2 server.
I am planning on 5 internal drives (1 HS) in a Raid 10 connected to a RS2BL080 card, but I do not know whether I need to need to order the SR1625URSAS or if I just need a particular riser card with the SR1625UR. It almost seems that in order to achieve 6 Gb/s you need to order the SR1625URSAS and some extra parts - Some please help.
I need some specific part numbers to order.
Paul
Daniel_O_Intel
For specific part numbers, you can walk through the configurator at http://serverconfigurator.intel.com/configure-ap.aspx?id=MjUxMSMxLDI2MTgjMg%3d%3d, or use the PDF (which is easier for me) at http://www.intel.com/support/motherboards/server/s5520ur/sb/CS-030024.htm
