Server Products
4852 Discussions
S5520sc with chassis s5300base Fan running high speed
vmoha1
Iam having s5520sc which is assembled in s5300 chassis , the fan inside running high speed. heavy noice coming out. why intel server chassis fans are high speed running and make noise that distrub a lot while working. how to solve it please help me.
Edward_Z_Intel
That's not a supported chassis, and you may encounter power/thermal issues.
See http://www.intel.com/support/motherboards/server/sb/CS-030213.htm Tested processor list.
Wattrelos
Hello!
Make sure that all mandatory pin fan is connected and respective fans are works.
Two processor fans;
Two front fans (pin 1 and pin3);
One rear fan (pin 5).
Cheers
