Server Products
4544 Discussions
SR2600URBPR with ASR26XXFHLPR five slot active riser do not recognize five PCIe v2.0 x2 cards based on Marvel 9230 chipset
MR15
Server stops diagnostics with 0x51code on diag leds - Allocating resources to PCI buses..
I take out the two cards - no problem..
I tried to put in two PCIe x4 intel network server cards instead controllers - the same situation - 0x51 code..
If you already tested the system with x4 or x8 cards you could be dealing with a defective riser card reason why we recommend contacting our support group directly for warranty replacement:
http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport
