Server Products
4842 Discussions
SR2600URBRPR - RAM update
RCiob
Hi All,
I have the below server and currently looking at upgrading RAM to max capacity according to https://ark.intel.com/products/48665/Intel-Server-System-SR2600URBRPR https://ark.intel.com/products/48665/Intel-Server-System-SR2600URBRPR
Prod.code
SR2600URBRPR
MN#
905666
SERIAL NO
BZDT11200526
TA NO
E86283-008
RAM Memory Specifications
Memory Types
DDR3 ECC UDIMM, RDIMM
Max # of DIMMs
12
Max Memory Size (dependent on memory type)
192 GB
Received help via this link https://www.intel.com/content/dam/support/us/en/documents/server-products/Intel-Server-System-SR2625URBRPR.pdf https://www.intel.com/content/dam/support/us/en/documents/server-products/Intel-Server-System-SR2625URBRPR.pdf to find out max HDD options but it does not say anything about my current endever.
Please help
n_scott_pearson
I found a storefront that detailed it this way (after translation to english):
2.5-inch compartmentsIt is possible to install 2 HDD when installing the separately sold ASR2600FXDRV. The devices installed in this way are connected to the SATA connectors on the motherboard3.5-inch compartments5 slots for SAS or SATA HDD with hot swappable, with the option of installing the 6th compartment with the optional ASR2500SIXDRV.
To use SAS HDD, you need a separately sold SAS controller.
Hope this helps,
RCiob
Many thanks Scott for your reply!
With the above expansions will we not reach the motherboard HDD limit?
If not – it would be really good news for us.
Do you have anything in terms of RAM Memory storage - the main concern on this inquiry ?
From the documentation I was able to put together the maximum seems to be 12 cards of 16 GB each .
Any recommendations for RAM?
My findings turned out the below:
Samsung M393B2K70CM0-YF8 16 GB Registered 1066 MHz Quad K4B4G0446C-MYF8 Samsung x4 1.35 Volts
Nanya* NT16GC72C4NB0NL-CG 16 GB Registered 1333 MHz Dual NT5CC1024M4BN-CG Nanya x4 1.35 Volts
Dataram DTM64356A 16 GB Registered 1333 MHz Dual K4B4G0446B-HCH9 rev B Samsung x4 1.5 Volts
Dataram DTM64327C 16 GB Registered 1066 MHz Quad K4B4G0446C-HCF8 rev C Samsung x4 1.5 Volts
Hello Robert,
Specifications for Supported memory is available at https://www.intel.com/content/www/us/en/support/articles/000008504/server-products.html Intel® Server System SR2600URBRPR
You could get more information about https://www.intel.com/content/www/xr/en/support/server-products/server-systems/2u-rack-server-systems/intel-server-system-sr2600ur-family/intel-server-system-sr2600urbrpr.html Intel® Server System SR2600URBRPR at https://www.intel.com/content/www/us/en/support/articles/000008504/server-products.html Supported Memory and Memory Population Rules for the Intel® Server...
Please let me know if you need more information.
Caesar B_Intel.
n_scott_pearson
Sorry, I have no direct experience with this board, so cannot comment on RAM choice. You are correct though, you need 12 16GB Registered DIMMs in order to max out the memory.
Hello N.Scott.Pearson ,
Thanks for your assistance on this thread.
Caesar B_Intel.
Hello Robert,
We would like to follow up with you on this case and find out if further assistance is required.
Caesar B_Intel.
Hello Robert,
We are wondering if further assistance is required.
Caesar B_Intel.
RCiob
Hello Caesar B_Intel,
While the reply is in the same region of the question asked, it does not provide the answer I am looking for.
Hello Robert,
We provided the specifications supported by the board.
Support for this board is limited to the website and the communities assistance. You could get more information about https://www.intel.com/content/www/xr/en/support/server-products/server-systems/2u-rack-server-systems/intel-server-system-sr2600ur-family/intel-server-system-sr2600urbrpr.html Intel® Server System SR2600URBRPR at https://www.intel.com/content/www/us/en/support/articles/000008504/server-products.html Supported Memory and Memory Population Rules for the Intel® Server...
Please let me know if you have any questions regarding the ram you chose.
Caesar B_Intel.
RCiob
was a very good link that clearly indicated that for my server SR2625URBRPR the correct storage should be the listed ones included in the PDF file.
Did find the RAM listings for the family server but not explicitly referencing my server as per the above link.
Was thinking there is an similar intel official link when it comes to RAM for SR2625URBRPR.
Intel family server documentation indicated that the below would be what I am after, but not 100% this is accurate as there are (small/big)chances these will not be compatible at all.
Hello Robert,
Please let me know if you need any other clarification from our team.
Caesar B_Intel.
RCiob
Hi Caesar B_Intel,
If possible please provide confirmed compatible RAM for my server like the one I got for HDD.
If not possible please close this tread as this is the sole reason I am here.
Robert C.
RCiob
This where I got all the original data for my post.Considering you are enforcing the same I can deduce that the referenced RAM should be compatible.
Thank you very much!
Hello Robert,
You are more than welcome.
We are glad to be of assistance.
CaesarB_Intel.
