Server Products
4793 Discussions
SRCSAS18E re: drive lights
FGoud
Hello all: We have a server running an SRCSAS18E board(or its onboard,not sure)
We had our boot drive mirror fail. I am going to be swapping out the failed drive in hopes that it will rebuild.
My actual question is related to some of the other drives in the server 2 of the 6 working drive lights are solid green while the others flash normally. i'm not sure if the solid green started after the drive failure or not.
Any ideas as to what the solid drive lights mean? they are both solid green which is better than Red. The server has not been rebooted.
Frank
Edward_Z_Intel
It may depend on your chassis and HDD backplane. In Intel chassis, solid green could mean drive powered on but no activity.
