Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4663 Discussions
SRCSASRB controller - adding config - lost partitions in Server 2008?
Hi guys,
Hardware is SRCSASRB running under server 2008. Added some new drive groups under config wizard...Selected "ADD Configuration". Then when I rebooted server 2008, the existing partitions are GONE! I didn't change anything to the existing drive config's. Now server is asking me to initialize the "NEW" drives, which I did not.
Any ideas how to get the partitions back? The controller wizard stated there would be NO data loss?!?
Jason
Daniel_O_Intel
If you reboot and go into the RAID card itself (Ctrl-C, or I, or G; I don't remember which), does it show your original RAID setup?
If not, *sometimes* you can recreate the exact same RAID setup, and *not* initialize the drives, and everything will be back the way it was before.
