Server Products
Data Center Products including boards, integrated systems, RAID Storage, and Intel® Xeon® Processors
5053 Discussions
modular server v2 problem
Hi all
Sometimes after rebooting comput module virtual drives not detected and after power off the modular server power supplys are unknown devices.
can any help me? server with full component and firmware 10.4
Daniel_O_Intel
The two most common issues are:
1) untested hard drives - check the list at http://www.intel.com/support/motherboards/server/MFS5520VI/sb/CS-030301.htm http://www.intel.com/support/motherboards/server/MFS5520VI/sb/CS-030301.htm
2) mixing hard drive manufacturers, models, or firmware revisions within the same storage pool. You can have different drives in the same chassis, you just have to make sure each storage pool consists of only one kind.
THank you Dan_O.problem was one of the two scm , with remove it from server and power off/on modular server problem solved.
