Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4550 Discussions
SS4000-E how to delete the system log?
as I want to sell my Intel ss4000-e I wanted to delete the system log, but I was unable to find a solution.
I already tired the reset botton on the back of the device but it was not succesful.
Thank you for your help
Chris
Chris,
Are you selling the disks with the system?
If so, see the article on http://www.intel.com/support/motherboards/server/ss4000-e/sb/CS-029880.htm System partition, volume and file system information for the SS4000-E. There you can see that the operating system is resident in flash memory on the SS4000, the flash operating system is copied to the /dev/md0 partition on the storage system array and runs from there.
From that we know that the writeable data is on the disks. If you want to "sanitize" the system for a new user, I'd suggest deleting all the existing data and selling a new clean system. This will include data, user accounts, shared folder configuration and system logs.
To do this you can pull each individual disk out of the SS4000 and install in a PC and format the disk. Do this to all the disks and then reinstall into the SS4000 and reinitialize as you did when you first set it up.
John
Chris,
John
