Hi, does anyone know the part number for the ODD/SSD power cable for the S2600GZ?
There's a 6pin connector on the motherboard that has a cable that breaks out to two SATA power cables. The board/intel chassis (R1208GZ4GCSAS) we got came with a single ODD power cable for an optical drive which doesn't have SATA power on, where as the R2224GZ4GCSAS chassis came with a single ODD/SSD to two SATA power cables.
The ODD/SSD (On the S2600GZ board) to two SATA power cables are the part we're after, but no where can I find the part number for it or where to order one from.
Daniel,
Take a look at the Intel® Server System family R1000GZ/GL and R2000GZ/GL http://www.intel.com/support/motherboards/server/r2000gz-gl/sb/CS-032832.htm Spares/Accessories List and Configuration Guide. There's a number of references to cables, either, stand alone or included in kits that may have what you need.
John
John: It's not listed, unless it's the "SATA ODD cable for rack chassis family – 880mm long " though, I think that's just a single ODD power connector, not from the motherboard to 2xSATA power.
What we're after is this:
I'm after this cable too. From where did you picture the above?
See here - http://www.intel.com/support/motherboards/server/sb/CS-033248.htm http://www.intel.com/support/motherboards/server/sb/CS-033248.htm
It seems it's inside 2U cable kit. Only 2U supports SATA SSD (on top PSU, or airduct). 1U is only for ODD, right ?
You're right, it's the cable that comes in the 2U kit. We need to order some more because we have several of the 1U intel chassis's and need to have a non-hotswap SSD inside them. (For the OS Install)
There's no molex/etc power inside, except for that ODD/SSD socket on the S2600GZ.
(Yes there's somewhere in the 1U chassis we can fit another 2.5" SSD)
Is it possible to order JUST the ODD/SSD 2x SATA power cable? (IPN: G19127-003)
Daniel -
Intel doesn't sell the G19127-003 as a separate cable. We used to have a spare parts service, but that stopped last year.
I could post the pinouts and wiring spec for you, though, if you'd like. Would that help at all?
Hi Dan_O,
If we could get the pinouts and wiring spec that'd be great!
Do you also have the part number for the connector that plugs into the 6 pin socket on the board?
Looking at the connector head-on from the bottom:
clip12V3.3VGND5V5VGNDThe connector is a MOLEX 0430300007
Micro-Fit 3.0™ Crimp Terminal, Female, with Tin Plated Tin/Brass Alloy Contact, 20-24 AWG, with
MOLEX 0430250608
3.00mm (.118") Pitch Micro-Fit 3.0™ Receptacle Housing, Dual Row, 6 Circuits
![](/skins/images/9701FEC4E90D143B667C09F3DB2F340F/responsive_peak/images/icon_anonymous_message.png)
