Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4663 Discussions
SSD SATA power cable for S2600GZ
DRich18
Hi, does anyone know the part number for the ODD/SSD power cable for the S2600GZ?
There's a 6pin connector on the motherboard that has a cable that breaks out to two SATA power cables. The board/intel chassis (R1208GZ4GCSAS) we got came with a single ODD power cable for an optical drive which doesn't have SATA power on, where as the R2224GZ4GCSAS chassis came with a single ODD/SSD to two SATA power cables.
The ODD/SSD (On the S2600GZ board) to two SATA power cables are the part we're after, but no where can I find the part number for it or where to order one from.
Daniel,
Take a look at the Intel® Server System family R1000GZ/GL and R2000GZ/GL http://www.intel.com/support/motherboards/server/r2000gz-gl/sb/CS-032832.htm Spares/Accessories List and Configuration Guide. There's a number of references to cables, either, stand alone or included in kits that may have what you need.
John
DRich18
John: It's not listed, unless it's the "SATA ODD cable for rack chassis family – 880mm long " though, I think that's just a single ODD power connector, not from the motherboard to 2xSATA power.
What we're after is this:
SBlitz
New Contributor II
I'm after this cable too. From where did you picture the above?
SBlitz
New Contributor II
See here - http://www.intel.com/support/motherboards/server/sb/CS-033248.htm http://www.intel.com/support/motherboards/server/sb/CS-033248.htm
It seems it's inside 2U cable kit. Only 2U supports SATA SSD (on top PSU, or airduct). 1U is only for ODD, right ?
DRich18
You're right, it's the cable that comes in the 2U kit. We need to order some more because we have several of the 1U intel chassis's and need to have a non-hotswap SSD inside them. (For the OS Install)
There's no molex/etc power inside, except for that ODD/SSD socket on the S2600GZ.
(Yes there's somewhere in the 1U chassis we can fit another 2.5" SSD)
Is it possible to order JUST the ODD/SSD 2x SATA power cable? (IPN: G19127-003)
Daniel_O_Intel
Daniel -
Intel doesn't sell the G19127-003 as a separate cable. We used to have a spare parts service, but that stopped last year.
I could post the pinouts and wiring spec for you, though, if you'd like. Would that help at all?
DRich18
Hi Dan_O,
If we could get the pinouts and wiring spec that'd be great!
Do you also have the part number for the connector that plugs into the 6 pin socket on the board?
Daniel_O_Intel
Looking at the connector head-on from the bottom:
clip12V3.3VGND5V5VGND
The connector is a MOLEX 0430300007
Micro-Fit 3.0™ Crimp Terminal, Female, with Tin Plated Tin/Brass Alloy Contact, 20-24 AWG, with
MOLEX 0430250608
3.00mm (.118") Pitch Micro-Fit 3.0™ Receptacle Housing, Dual Row, 6 Circuits
