I started a couple jobs yesterday and checking the documentation I couldn't execute simple commands such as qstat -f <JOB ID>. Here some examples:
qstat (works perfectly and shows the current active jobs)
XXXX.v-qsvr-1 <script> <uXXXXX> 05:03:57 R batch
but if I use qpeek to check this jobs, here the outputs:
qpeek -o XXXX.v-qsvr-1
qstat: Unknown Job Id Error XXXX.v-qsvr-1
Job XXXX.v-qsvr-1 is not running!
I can't even delete a current job
qdel XXXX.v-qsvr-1
qdel: nonexistent job id: XXXX.v-qsvr-1
What am I doing wrong? Thanks!
David Molina
I'm sorry if I classified wrong this question I couldn't find an option for DEVCLOUD. 🙂
Hi David,
Thank you for contacting us about this concern.
I would like to refer you to the following Forum, please check the link below:
https://forums.intel.com/s/topic/0TO0P00000018NNWAY/
Feel free to ask on that site any question and they will be more than happy to assist you about the DEVCLOUD information.
Emeth O.
Under Contract to Intel Corporation.
I will ask in the other forum! May you delete this post. I couldn't do it. Thanks!! 🙂
Topic Options
