Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4661 Discussions
System Board Voltage Health Red
Hello, I have a problem with the S2600GZ motherboard, in the BMC in the logs shows the health voltage is red,
BMC sensor logs
in esxi event logs
bios,bmc,fru-sdr updated! help me please, and sorry for english from google translater )
Hello Suleyman05,
With the Voltage RED LED, normally could be related to the power supply or power distribution.
Could please help me with additional information:
  • Chasis model number
  • Number of power supply and model
  • Number of CPU's and model
  • Memory distribution and model.
  • Storage configuration and model.
And any additional information you can provide us.
Also, please ensure you have the latest BIOS Running:
https://downloadcenter.intel.com/download/27786/Firmware-Update-Package-Update-for-EFI-Intel-Server-Boards-and-Intel-Server-Systems-Based-on-Intel-60X-Chipset?product=56253 https://downloadcenter.intel.com/download/27786/Firmware-Update-Package-Update-for-EFI-Intel-Server-Boards-and-Intel-Server-Systems-Based-on-Intel-60X-Chipset?product=56253
Please help me with the system logs:
https://downloadcenter.intel.com/download/26988/System-Event-Log-SEL-Viewer-Utility?product=56253 https://downloadcenter.intel.com/download/26988/System-Event-Log-SEL-Viewer-Utility?product=56253
Thank you for help and support.
Henry A.
Hello Henry, here is more information
attached more screenshots with information )
Hello Suleyman05,
Thank you for the updated information. Last option will be to reset and swap power supply position.
If the problem persists then will be to contact Support, but double checking the pictures you provided 06.png, the serial number on the board QSGR41703001, the warranty expired on 08/13/2017.
If you can find a POP with a different date for the 3-year warranty.
I will then recommend you to contact Server suppor for RMA request.
Henry A.
Hello Suleyman05,
I just wanted to follow up if you had the opportunity to swap power supply positions.
I will then recommend you to contact Server support for RMA request.
Henry A.
Hello Suleyman05,
I am sorry but we haven't heard back from your with the information requested.
I will proceed and close the thread
Henry A
