(Re-post from desktop mobo - sorry for the double)
I am trying to update my S5520SC to R0069.
Currently my system is S5520SC.86B.01.00.0057. The readme for R0069 suggests to update to at least BIOS 66 before updating to R0069.
Option C. under "Updating from BIOS revisions R0018 or later:" it states: C. Instruction for R0066 and later version update
1. Boot the system to EFI Shell
2. Copy IFlash32.efi and BIOS .CAP file to a HD or USB Flash Drive
( Do not use the Rec.CAP file as it will clear NVRAM and should
only be used for Recovery - See Recovery Instructions below )
3. Map the respective storage device in system with the command
Shell> map -r
4. Change the Shell to mapped device file system
Example: Shell> fs0: (or fs1:)
5. iflash32 /u /ni T066.cap
6. Reboot system after the update is completed.
7. Do *NOT* interrupt the BIOS POST during the first boot.
8. Boot to UEFI Shell again, then change the Shell to mapped device file system
9. iflash32 /u /ni /nv R0066.cap
10. Reboot system after the update is completed.
If it's R0066 or later why do you need the transition capsule? or flash to R0066? Should this read Instruction for less than R0066 version update?
Essentially I would like to know if I can use option C to update to R0069 from my current R0057 (i.e. follow option C to update R0066, then flash to R0069)
J
Hello jo_5456,
Yes, I am afraid it may look a little confused.
But for BIOS prior ( I think is R0045) it had to be done Updating from BIOS revisions R0018 or later.
But you are running 0057 the follow, Instruction for R0066 and later version update
Then Flash R0069.
If there is anything else we can help please feel free to ask.
Henry A.
Hello jo_5456,
I just wanted to follow up on your threat for the BIOS update on an S5520SC.
Henry A.
Hello jo_5456,
I am afraid we have not received any update from your threat for the BIOS update on an S5520SC.
I will proceed on closing this threat. If you require any additional help, I will recommend to open a new Threat and refer back to this one.
Henry A.
